API call to generate a base
Hi People,
The documentation says:
’ SeaTable knows three different tokens
  • An Account-Token authenticates an account API request (=Account Operations) like add a new base, add a group member or list all collaborators of a base. The Account-Token can be generated with the account-credentials.’
But I really can’t find any API call in the reference to do that. What do I miss out?
From the API documentation at https://api.seatable.io:
Get Account Token with Username and Password: Introduction
With the account token, you can authorize account operations:
Create base: Introduction
Thanks. I have that token part already implemented. But I can not find an API call to create a new base… But the documentation claims that this is possible (marked as bold text)
Ahh, I oversaw your link. thank you very much, that helps :slight_smile:
