# Authentication issue in custom application
**URL:** <https://forum.seatable.com/t/authentication-issue-in-custom-application/108>\
**Category:** Integrations\
**Tags:** postman\
**Created:** [October 23, 2020, 6:30pm UTC](https://forum.seatable.com/t/authentication-issue-in-custom-application/108 "2020-10-23T18:30:04Z")\
**Posts on this page:** 8\
**Page:** 1
<div class="post-metadata">
**Author:** ![divyanshu](https://forum.seatable.com/letter_avatar_proxy/v4/letter/d/e495f1/32.png) [@divyanshu](https://forum.seatable.com/u/divyanshu)\
**Post date:** [October 23, 2020, 6:30pm UTC](https://forum.seatable.com/t/authentication-issue-in-custom-application/108/1 "2020-10-23T18:30:04Z")
</div>
Hi
i am building a custom pages over the seatable. i am facing the issue to process the session id and token on my custom pages. How could i resolve this issue?
Thanks
**Author:** ![daniel.pan](https://forum.seatable.com/user_avatar/forum.seatable.com/daniel.pan/32/13_2.png) [@daniel.pan](https://forum.seatable.com/u/daniel.pan)\
**Post date:** [October 24, 2020, 2:37am UTC](https://forum.seatable.com/t/authentication-issue-in-custom-application/108/2 "2020-10-24T02:37:44Z")
</div>
Can you talk more about what you want to achieve? If you deploy your pages with a different domain, the session token will not send to your pages.
**Post date:** [October 26, 2020, 7:34am UTC](https://forum.seatable.com/t/authentication-issue-in-custom-application/108/3 "2020-10-26T07:34:32Z")
</div>
we are deploying with same domain but we are mapping through NGINX server.
**Post date:** [October 26, 2020, 1:05pm UTC](https://forum.seatable.com/t/authentication-issue-in-custom-application/108/4 "2020-10-26T13:05:39Z")
</div>
You can look at the code about Django handle session and use the session table directly as you can get the session token in your application.
**Post date:** [October 27, 2020, 3:43pm UTC](https://forum.seatable.com/t/authentication-issue-in-custom-application/108/5 "2020-10-27T15:43:38Z")
</div>
Thanks daniel
can you elobrate how exactly i can pass and where(path) i can find the session id?
**Post date:** [October 28, 2020, 9:14am UTC](https://forum.seatable.com/t/authentication-issue-in-custom-application/108/6 "2020-10-28T09:14:55Z")
</div>
You can check the browser using Chrome’s debug mode. Looking at the HTTP request’s header part.
**Author:** ![rdb](https://forum.seatable.com/user_avatar/forum.seatable.com/rdb/32/1869_2.png) [@rdb](https://forum.seatable.com/u/rdb)\
**Post date:** [October 29, 2020, 9:24pm UTC](https://forum.seatable.com/t/authentication-issue-in-custom-application/108/7 "2020-10-29T21:24:59Z")
</div>
Did this answer your question? If yes, please mark as solved!
**Author:** ![Martiking](https://forum.seatable.com/letter_avatar_proxy/v4/letter/m/71c47a/32.png) [@Martiking](https://forum.seatable.com/u/Martiking)\
**Post date:** [November 19, 2020, 12:04pm UTC](https://forum.seatable.com/t/authentication-issue-in-custom-application/108/8 "2020-11-19T12:04:23Z")
</div>
This helps!
[https://forum2.seatable.io/t/tutorial-use-api-in-postman-and-convert-into-every-language/125](https://forum2.seatable.io/t/tutorial-use-api-in-postman-and-convert-into-every-language/125)
