Bar Charts displaying all single-select options
Your Setup:
  • SeaTable Cloud
Describe the Problem:
I am using a bar chart in the apps dashboard page and the report design plugin. The x-axis refers to a column of type “Single-Select”. I can now see the amount of rows that selected various single-select options. I can even see the amount of rows that did not select an option at all.
Would it be possible to add a setting, so that I can also see the amount of rows (zero) for the single-select options that were not chosen at all?
I would like to display a bar chart for feedback about a workshop. (i.e. did you like the workshop? very much, some, not very, i hated it). I would like all options to be visible even if 0 interviewees selected them. So that the person reviewing the data knows what options were available to select from.
It would also be amazing if it was possible to sort the bars not only by rising or declining values but also alphabetically.
Thank you for taking a look at this.
Kind regards, Béla
Please add your feature requests at https://ideas.seatable.com
