Cascade Single Select - 'Match table'?
Your Setup:
  • SeaTable Cloud
Hello,
I have found that Seatable supports the Cascading feature for Single Selection. That’s very nice. :+1:
However, is there a way to enter the data in a less interactive way?
Let me explain:
Suppose I have to put 20 countries in the parent column and 10 main cities for every country in the subordinate column. Using the current method, I have to make 20x10 = 200 options and 200 point-and-clicks.
I have the countries and cities in another spreadsheet (database table) that I call “Match Table”. Is there a way to make Cascading feature read that Match table?
TIA
This is currently not supported.
If you have a lot of options, you can use the API to automate the column’s configuration: Update Column Cascade Settings
