I need to check if the integer in a cell is equal to the number of files uploaded in another cell. Is it possible to achieve this with a formula?
Welcome to the Forum!
Sure, you can do that. You need four columns (you can also do it in three, but this is more transparent):
- number column for your integer
- file column for your files
- formula column with
countitem()countitems()function - formula column with
if()function
Then you can also use condition cell formatting to highlight all cells in which the result of the if formula is a particular value.
Neat application!
Thanks for the solution, it works like a charm! The function turned out to be countitems() though and I was left scratching my head for a bit but it’s all good.
Oh sorry, you are right.
Glad you figured it out.
