Connect bases with each other
Setup:
  • SeaTable Cloud
Question:
Is there a way to connect two or more bases with each other?
For example, I have a CRM base with a table dedicated to Accounts that we are trying to work with.
I wanted to create a new base for Ongoing projects, and each Project should be linked to an Account.
Can I create a shared base for Accounts that is then used by both bases (CRM and Ongoing projects)?
You cannot link recrods in different bases. This is currently not supported.
Please take a look at the common dataset feature instead.
Thank you!
Hello @fpiovesan
I don’t have all the information about your needs, but maybe you can find a solution using a common dataset.
Please find attached official seatable help related to shared dataset.
