Hello,
Is there a way to specify the paper size in mm for the page design. We want to print labels. In general, it is difficult to work with “pixels” when printing. Does anyone have a solution?
Nicolas
Hello,
Nicolas
Hi,
my spontaneous idea would be to use a converter from Din format to pixels.
But I can’t say if this is the best solution.
Hello fsa, thx but it dosnt work. in seatable you only can use pixel. a pixel is no fix size its a element not a size for analog designs. THX Nicolas
