Export Base larger than 100mb
is it not possible to export a base larger than 100mb?
When I try to export the error appears:
Sorry for the late reply: Yes, unfortunately, you cannot export bases larger than 100MB.
Why does that happen? Is there a limitation somewhere?
That’s a limitation of SeaTable, and cannot be changed momentarily. Sorry!
Hello , are we able to remove this limitation?
I am using self hosted seatable.
Yes, you can: https://manual.seatable.io/config/dtable_export_max_size/
That link is a 404. How do I remove the limit in the Developer Edition?
Thanks.
