Hi
I’ve tried to export a view via API as described under Introduction
I followed the instructions, tested with Postman and curl, but I get everytime the response
{ "detail": "Invalid token" }
Is there a problem with this function or what I am doing wrong?
The error message is clear: “Invalid token.”
Please make sure you use the right token. SeaTable distinguishes between “auth token” and “base access token”
Hi I know about the difference of the token. The auth token can be generated for a base and is the master key. It is also used to generate the base access token. I have tried with both token and both didn’t work. Same error message.
