Your Setup:
- SeaTable Self-hosted?
- SeaTable Version: 6.1.0 Developer
In the workflow setting, there is no Share button at the top menu.
Neither there is Allow access to workflow by link option in the setting.
The workflow feature is a deprecated feature and is turned off on by default.
I recommend you build a workflow using the app building feature instead.
The workflow feature is for the Chinese market only. It was never marketed/documented/promoted outside of China.
How to use app building feature to simulate a workflow?
Here is a general idea. Workflow essentially is multi-steps task. Each step, a record have an assigned person to fill some information.
So for each step in the workflow, you can create a page and use filter condition where a user can only view records that assigned to this user.
