I have 2 tables, one named lessons and another named slides.
The slides table has a formula column named “Slide OK?”. The formula returns true if both conditions are met:
- Checks if there is only one file in the “Slide Info” column.
- Compares the number of files in the “Slide Assets” column to the integer in the “Sections” column.
The lessons table has a formula column named “Slides OK?” that compares the integer in the “Number of Slides” columns to the number of linked records in the “Slide Entries” column.
I need to make a new column in the Lessons table that returns true if all of the following conditions are met:
- The value in “Slides OK?” column (Lessons table) is true.
- The value in “Slide OK?” column (Slide table) is true for all of the linked records in the “Slide Assets” (Lessons table) column.
How would I go about achieving number 2?
