# Notifications via Mail: Links always point to vid=0000 (aka Default View)?
**URL:** <https://forum.seatable.com/t/notifications-via-mail-links-always-point-to-vid-0000-aka-default-view/6367>\
**Category:** Collaboration & Sharing\
**Tags:** limits\
**Created:** [March 6, 2025, 10:34am UTC](https://forum.seatable.com/t/notifications-via-mail-links-always-point-to-vid-0000-aka-default-view/6367 "2025-03-06T10:34:23Z")\
**Posts on this page:** 1\
**Page:** 1
<div class="post-metadata">
**Author:** ![abaer](https://forum.seatable.com/user_avatar/forum.seatable.com/abaer/32/4748_2.png) [@abaer](https://forum.seatable.com/u/abaer)\
**Post date:** [March 6, 2025, 10:34am UTC](https://forum.seatable.com/t/notifications-via-mail-links-always-point-to-vid-0000-aka-default-view/6367/1 "2025-03-06T10:34:23Z")
</div>
## Your Setup:
- SeaTable Self-hosted
- SeaTable Version 4.4.9 and 5.2.7 latest
## Describe the Problem/Error/Question:
Less an issue, more a question about the intended behaviour.
We noticed that e-mail-Notification links to records (e.g. when somebody mentions another user in the comments for a record) always refer to the first view of a table. In technical terms, the link contains &vid=0000, which is the “Default View” when you first start a table.
More often than not, users have no right to access that view, or the view is filtered, not showing the record the notification link points to. As a consequence, people need to manually identify and find the record in question in order to see the comment.
I’m not sure whether it’s logically possible to find a better solution, but first questions first: Is that the intended behaviour, and unavoidable? I image that there are situations where a comment is placed in a record that the person who is mentioned and notified has no right to access - bad luck.
But there might be a better solution than just referring the links to the default view?
