Question about copying bases
External Apps (HTML pages, the Single Record view, the whole App Builder) are tied to the specific base — each base has its own unique internal ID. When you duplicate/copy the base, SeaTable creates a new base with its own ID, and the external Apps don’t come along with the copy, because they’re technically a separate resource, not something “inside” the tables.
In practice, this means:
  • Tables, data, button scripts, views → these do copy over fine with the base.
  • External Apps (HTML dashboards, Employees Data) → these need to be recreated by hand in every new copy.
No. If you toggle the Include assets checkbox when copying a base, any universal apps attached to the base are also duplicated.
