Quick & dumb question: Menu item "Workflows"
The title says it all, but I couldn’t find any information:
What (which workflows) is supposed to appear under the menü item “Workflows“ in the system Administration? We run Webhooks, n8n automations, Python scripts and the like, and still the list is empty.
grafik
Thanks!
This Workflows is a unpublished and unfinished feature. Normally, it should not appear at the interface. Maybe you have turned on some undocumented configurations that causing it be shown.
@daniel.pan , thanks for the quick answer, I and other admins can live with that. Running a system that dates back to Seatable 2.x probably caused that, but no we know that this is supposed to be empty. Just cosmetic.
