Hi.
I have a column that is related to another table. The only restriction is you can only select one entry at a time. But when I remove the selected item it doesn’t show up again in the list. I have to close the list and open up again. It seems like bug to me.
Step 1: Select an item
Step 2: Remove it
Step 3: The removed item doesn’t show up
Step 4: After closing the selection list and opening it up again, the item is back
