SeaTable provides Restful API, so we can easily write data through HTTP protocol from anywhere. In this article, we mainly introduce how to use SeaTable to record the error logs of various services on the server, realize the visualization of the logs, and prevent the error messages from being ignored.
The main process is as following:
Filebeat Python Script
Log files -------------> Redis ------------------> SeaTable
Features include
- The log is placed in a code block in Markdown format and recorded in the long text column of SeaTable
- We can use SeaTable’s multi-view function to create multiple different views, each view includes specific filter conditions, which is convenient for us to quickly view data
Let’s introduce the construction process in detail below.
Use filebeat to send logs to Redis
Take Ubuntu 20.04 as an example, use the following command to install filebeat
apt update && apt install filebeat -y
Config filebeat (You can find an example at seatable-syncer/log-sync/filebeat.yml at main · seatable/seatable-syncer · GitHub):
vim /etc/filebeat/filebeat.yml
filebeat.inputs:
- type: log
paths:
- /opt/seatable/shared/seatable/logs/dtable_web.log
tags: ["dtable-web"]
multiline.pattern: '^[0-9]{4}-[0-9]{2}-[0-9]{2}|^\[[0-9]{4}-[0-9]{2}-[0-9]{2}'
multiline.negate: true
multiline.match: after
- type: log
paths:
- /opt/seatable/shared/seatable/logs/dtable-server.log
tags: ["dtable-server"]
output.redis:
hosts: ["redis host"]
password: "redis password"
db: 0
timeout: 5
keys:
- key: "seatable-error-logs"
when.contains:
message: "[ERROR]"
Note: we use multiline match pattern to match multiple lines as a single log item,
the beginning of a log item is 2021-10-12 or [2021-10-12. In the last line message: "[ERROR]", we only send log items containing string “[ERROR]” to Redis.
Finally, start filebeat:
service filebeat start
Reading logs from Redis and save to SeaTable using Python script
Preparing SeaTable base
- First, generate an API Token from the base
- Create a table with following columns
| Name | Is first column | Type |
| Service | √ | Text column or single select column |
| Time | x | Date column with minutes |
| Log | x | Long text column |
Preparing the script
Download and install the script to /opt/
cd /opt
git clone https://github.com/seatable/seatable-syncer.git
Install Python libraries
cd seatable-syncer/log-sync/
pip3 install -r requirements.txt
Modify the configuration file opt/seatable-syncer/log_sync/settings.py
# SeaTable
server_url = 'Your SeaTable server URL'
api_token = 'the API token you created'
table_name = 'table name'
# Redis
redis_host = 'your redis host'
redis_db = 0
redis_port = 6379
redis_password = None
Starting the script
python3 log_syncer.py
log_syncer.py can handle log items start with following strings:
2020-01-01 01:02:02
2020-01-01T01:02:02
[2020-01-01 01:02:02
[2020-01-01T01:02:02
If you have logs in other formats, you can modify the script accordingly.
That’s it
With filebeat, Redis and Python scripts, we can collect logs from multiple servers into a base in SeaTable. Through the filtering conditions of the table and the multi-view function, we can easily analyze and view the log.
