Hello,
I’ve discovered seatable and it’s really a nice tool.
I’m currently trying to figure out how to get the best of it.
Few limitations are currently hitting my progression.
Some items that would be great if added :
dates by week number instead of date by day (with the possibility to choose between US and European style)
a cell type that would be : calendar list
In this specific field, you would have week numbers or dates associated with a short text.
2021/02 - blabla
2021/03 - blablablo
2021/07 - bliblubli
and so on…
and these items to be displayed on the calendar, instead or in addition with the whole range of the project/task
an easier deployment system… docker was a pain to set in my environment that is mostly LAMP…
email notification reminders to assignees. I’m not sure it’s actually feasible at the moment. I can get table notification to a specific user, but not by task assigned. like reminder for a task 2 days before end date ?
statistics : that would be great to be able to display multiple columns as different variables on the same graph.
welcome to the SeaTable Forum! Glad to hear you are interested in SeaTable.
As you might already have discovered, SeaTable is a highly customizable tool with a SaaS UI. In most cases, the very specified user requirements can be carried out with some self-made loops. The joy of using SeaTable is that you can DIY many things!
So, for the dates and week number: SeaTable has a function weeknum() that enables you to retrieve week number of a given date. When you create a new “Formula” column, you can use this function to return the week number of a date from another date column.
Then, you can concatenate this week number with the result from the year() function and the text from a text column and get your result:
As for the email notification problem you reported: Do you mean you cannot receive email notifications? As the default email settings in the personal settings is disabled for emails:
Make sure the setting of “Notifications of collaboration” is not set to “Don’t send”.
And as for the statistics: I’m not sure if I have understood you correctly…did you mean you want to display the values from different columns grouped in the same figure? This is possible, just select “Add new numeric column” in the Data grouping setting:
So in this example, I have three numeric columns:
With the above settings, I can display them in the same figure:
week number
I get the idea, but it would be much more comfortable to have a format of date cells as ‘week nb’, and a calendar view by week. at least, in my way of working.
I would need something more compact than that.
1 line in my main table list 1 project.
For each project, I have a calendar of tasks to be performed. I would like to list in one cell all tasks with their dates, and this cell-calendar would be displayed on the main calendar plugin, one color per project. I may overstrech the capabilities of the table, but that’s my current limitation.
In my actual excel table, I’m using a row per week number, listing tasks for each week, but i was looking for something more efficient. I’ll dig around to find a clever way
I don’t have any email notification setting in my personal menu !?
Is it in /profile/ ? I have only the possibility to change my email, my password, language and to delete my account.
for the statistic, i’m filling my table with a form that get’s single choice among 5 (Rating scale 1 to 5), so it’s not a numeric value, therefore, it’s not listed in the numeric column list.
I could put a numeric format to the cell, but then, the form would just ask for a number, without a single choice scale that works better in my opinion. I have tried a formula trick like left({my single choice},1). it’s sadly not available in the numeric list for the statistics though the value is well displayed in the column as a number.
EDIT : for point 4, I managed to do it ! i had to transform the string as value, and then the column appeared in my list of possible choices for the statistics. the correct formula is value(left{single choice,1})
I’m using the 1.6.0 version - selfhosted docker
The server is able to send emails, as I’ve performed the mentioned steps.
I receive password reset emails and registrations emails too
but no email settings are present.
I’ve also added in dtable-event.conf :
[EMAIL SENDER]
enabled = true
The latest SeaTable for Docker is 1.7. Would you consider an upgrade?
And - if you are using the Developer Edition - did you know if you have no more than 3 users, you can use the Enterprise Edition for free, which has more features?
Here’s how to get the Enterprise Edition: https://forum2.seatable.io/t/get-seatable-enterprise-edition-in-3-minutes/307?u=karlheinz
If you consider an upgrade to the latest version: the new version also has a lot of UI improvements, details can be found in the SeaTable Changelog:
If the extra features in the Enterprise Edition is not that important to you, the Developer Edition is free permanently. I’m not aware that there are other software like SeaTable that can be self-hosted
As long as all expected items are present in the developer edition, I would be totally happy
And once a new software is established in our team pipeline, we would consider moving to enterprise edition. We usually decide after 2 years of use, not before. eg. we have a full licence for seafile for our >500 team
I’m sure SeaTable will be even better in 2 years. Now, SeaTable is only 8 months old, and we’re still developing features and improving the UI. User’s feedback is hence important to us.
I’m not an expert on docker, so let’s wait for the answer of @daniel.pan about your email settings…
