The formula works in DB. But in single record page, I get a “#Value” error.
One of columns used in formula is a single select type. And obviously, error comes from this column as I don’t get any arror when I have only text columns in formula.
Same problem appears while using de “concatenate” fonction.
I also tried to use “if” fonction to get a text for each single select option. I still have no problem in DB, but the text from the “if” fonction doesn’t appear in mysingle record page.
Is that the expected behaviour ? Or a well known bug ?
I was not able to reproduce your problem, but I previously encountered a quite similar problem when the content of some of the columns used in the formula (for example here your Indivision single-select column) were not available because they had been filtered in the page settings. The single record page doesn’t seem to offer this setting, but seeing you other posts I thought you may be in the somehow special case of a single record page displaying a table of linked items, and that this could cause the problem and require some special setting…
