424: Seatable Connot read properties of undefined
Hey, I am using make (integromat) to automate some things, and now I’m getting this error when opening the module. Do you know what I can do there? Somehow this suddenly stopped working? Is it because of Seatable or make? Are the servers down?
I didn’t find status code 424 in the seatable API documentatin at all.
Can someone help me there?
Hi @Lukas.
Do you have a column called “map”? If that’s the case and the error says “undefined” it could be because the value would only show up if it has a value.
I found the Problem. It is pretty stupid because I forgot to add options to some multi-select fields. :man_facepalming: And that created the Error.
