Hi,
After upgrading to 5.1 from 4.4, I got a 502 bad gateway error when loading base.
I’m using dev edition.
I read the other forum related talks, but I can’t figure out how to solve my problem.
I found that my dtable-db server do not responds to ping :
# curl --request GET --url https://seatable.<mydomain>/dtable-db/ping --header 'accept: application/json'
<html>
<head><title>502 Bad Gateway</title></head>
<body>
<center><h1>502 Bad Gateway</h1></center>
<hr><center>nginx</center>
</body>
</html>
But it’s running :
root@92db1b0958bd:/opt/seatable# ps -ef | grep dtable
root 1171 1 0 11:02 ? 00:00:02 python main.py --config-file /opt/seatable/conf/dtable-events.conf --logfile /opt/seatable/logs/dtable-events.log
root 1177 1 0 11:02 ? 00:00:00 /usr/bin/python3 /opt/seatable/seatable-server-latest/dtable-web/thirdpart/bin/gunicorn seahub.wsgi:application -c /opt/seatable/conf/gunicorn.py
root 1179 1177 0 11:02 ? 00:00:02 /usr/bin/python3 /opt/seatable/seatable-server-latest/dtable-web/thirdpart/bin/gunicorn seahub.wsgi:application -c /opt/seatable/conf/gunicorn.py
root 1190 1177 0 11:02 ? 00:00:02 /usr/bin/python3 /opt/seatable/seatable-server-latest/dtable-web/thirdpart/bin/gunicorn seahub.wsgi:application -c /opt/seatable/conf/gunicorn.py
root 1191 1177 0 11:02 ? 00:00:02 /usr/bin/python3 /opt/seatable/seatable-server-latest/dtable-web/thirdpart/bin/gunicorn seahub.wsgi:application -c /opt/seatable/conf/gunicorn.py
root 1194 1177 0 11:02 ? 00:00:02 /usr/bin/python3 /opt/seatable/seatable-server-latest/dtable-web/thirdpart/bin/gunicorn seahub.wsgi:application -c /opt/seatable/conf/gunicorn.py
root 1195 1177 0 11:02 ? 00:00:02 /usr/bin/python3 /opt/seatable/seatable-server-latest/dtable-web/thirdpart/bin/gunicorn seahub.wsgi:application -c /opt/seatable/conf/gunicorn.py
root 3363 3349 0 11:17 pts/0 00:00:00 grep --color=auto dtable
So I check my nginx.conf, it seems fine to me :
log_format seatableformat '[$time_iso8601] $http_x_forwarded_for $remote_addr "$request" $status $body_bytes_sent "$http_referer" "$http_user_agent" $upstream_response_time';
upstream dtable_servers {
server 127.0.0.1:5000;
keepalive 15;
server {
server_name seatable.<mydomain>;
listen 80;
# for letsencrypt
location /.well-known/acme-challenge/ {
alias /var/www/challenges/;
try_files $uri =404;
proxy_set_header X-Forwarded-For $remote_addr;
location / {
add_header Access-Control-Allow-Origin *;
add_header Access-Control-Allow-Methods GET,POST,PUT,DELETE,OPTIONS;
add_header Access-Control-Allow-Headers "deviceType,token, authorization, content-type";
if ($request_method = 'OPTIONS') {
return 204;
proxy_pass http://127.0.0.1:8000;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Host $server_name;
proxy_read_timeout 1200s;
# used for view/edit office file via Office Online Server
client_max_body_size 0;
access_log /opt/nginx-logs/dtable-web.access.log seatableformat;
error_log /opt/nginx-logs/dtable-web.error.log;
location /seafhttp {
rewrite ^/seafhttp(.*)$ $1 break;
proxy_pass http://127.0.0.1:8082;
proxy_request_buffering off;
proxy_connect_timeout 36000s;
proxy_read_timeout 36000s;
proxy_send_timeout 36000s;
access_log /opt/nginx-logs/seafhttp.access.log seatableformat;
error_log /opt/nginx-logs/seafhttp.error.log;
location /media {
root /opt/seatable/seatable-server-latest/dtable-web;
location /socket.io {
proxy_pass http://dtable_servers;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection 'upgrade';
proxy_redirect off;
proxy_buffers 8 32k;
proxy_buffer_size 64k;
proxy_set_header Host $http_host;
proxy_set_header X-NginX-Proxy true;
access_log /opt/nginx-logs/socket-io.access.log seatableformat;
error_log /opt/nginx-logs/socket-io.error.log;
location /dtable-server {
return 204;
rewrite ^/dtable-server/(.*)$ /$1 break;
proxy_redirect off;
proxy_set_header X-Forwarded-Proto $scheme;
# used for import excel
client_max_body_size 100m;
access_log /opt/nginx-logs/dtable-server.access.log seatableformat;
error_log /opt/nginx-logs/dtable-server.error.log;
location /dtable-db/ {
return 204;
proxy_pass http://127.0.0.1:7777/;
proxy_redirect off;
access_log /opt/nginx-logs/dtable-db.access.log seatableformat;
error_log /opt/nginx-logs/dtable-db.error.log;
location /api-gateway/ {
return 204;
proxy_pass http://127.0.0.1:7780/;
proxy_redirect off;
access_log /opt/nginx-logs/api-gateway.access.log seatableformat;
error_log /opt/nginx-logs/api-gateway.error.log;
My dtable_server_config.json includes :
"redirect_list_rows_api": true,
"dtable_web_service_url": "https://seatable.<mydomain>/"
And finally restarting does not help.
Any other ideas ?
