Check out node-red-contrib-seatable (node) - Node-RED to access the data in your Seatable bases.
Thanks for sharing!
Are you the sponsor/developer of the Node-Red SeaTable node?
Hi,
I’m the developer.
kr,
Jo.
Great! Then thanks for putting your time into it!
May I ask what is your use case?
We have a number of (IT) employees who capture data in SeaTable using the relational capabilities of Seatable for lookups etc.
Then we extract the data from SeaTable to process it in neo4j, a graph database, and neodash, a dashboard reporting application for neo4j.
Cool!
