- Is it possible to add collabs using scripting (JS) ?
- How do I use a common dataset from base A to link up data in base B so that both ways data is modifiable.
Edited: in a previous reply I wrote it was not possible per API. This is not true.
When parsing the request in the API request you need to write the IDs of the collaborators between [], like this:
However, the same doesn’t work with JavaScript yet.
- I’m afraid common dataset is only one-direction. Perhaps you have to build a Zap in Zapier to implement that, but I’m not sure it’ll work. Refer to this post for more details.
