Adding a Base as a new Template to the existing pool of templates
Let’s say I create an “interesting” base. Can I give it to the community and let it add to the pool of already existing templates?
Hey TOMO,
thanks, that you wanna share your base to the community.
At the end of the page Vorlagen - SeaTable you will find a link to a SeaTable Form where you can suggest a new template. Please provide a detailed description and add your exported Base as .dtable file. I will check your suggestion and decide if I will add your base to the list of existing templates.
Best regards
Christoph
