After Updgrade 4.3-> 4.4: "This Base needs to be migrated to storage-server"
Hi all,
using seatable enterprise, after upgrading from 4.3 to 4.4 today I get the following error message when I try to open SOME of my bases:
In the admin area, I can see that the bases affected by this error show no size:
(in this case, the base “CONTROLLER” gives the above error message, while “ckb” opens correctly.
What can I do?
Best regards
Simon
P.S.: I would be very helpful for quick help because the database is used in a productive environment.
After switching back to 4.3 it looks like access to the bases unaccessible in 4.4 is ok again. Looking at their date of creation I speculate that the affected bases might use seaf-server instead of dtable-storage-server, which was introduced in ver 3.0.
Is there any way to automatically migrate old seaf-server bases to dtable-storage-server bases? Or to re-activate backward-compatibility for seaf-server bases in 4.4?
Thanks!
Simon
Your assumption is completely right. Only bases that were created with version 2.x or 1.x are affected.
You find the necessary migration steps at: Extra Upgrade Notices - SeaTable Admin Manual.
I am sorry, that I didn’t update the page immediately this morning after we published the new version.
Great - with your help I could migrate the bases and everything works fine again.
Thanks a lot!
Simon
