Hi folks
I’m trying to migrate an Airtable base to Seatable (https://cloud.seatable.io) using the current migration script and the instructions at
But the script contains a lot of errors, which makes me wonder why no one has noticed this yet.
Line 49: The closing quotation mark is missing
Line 66 should be: base = Base(api_token, server_url)
Line 74 should be: links=links,
After these corrections, I can perform the first step of the migration (import-header).
But if I try the final migration (import-rows) I get the following error:
error: Error: line 90, in <module> import_rows() File "index.py", line 83, in import_rows convertor.convert_data() File "/usr/local/lib/python3.7/site-packages/seatable_api/convert_airtable.py", line 508, in convert_data self.delete_demo_rows() File "/usr/local/lib/python3.7/site-packages/seatable_api/convert_airtable.py", line 599, in delete_demo_rows self.batch_delete_rows(table_name, row_ids) File "/usr/local/lib/python3.7/site-packages/seatable_api/convert_airtable.py", line 727, in batch_delete_rows self.base.batch_delete_rows(table_name, row_id_split) File "/usr/local/lib/python3.7/site-packages/seatable_api/main.py", line 408, in batch_delete_rows return parse_response(response) File "/usr/local/lib/python3.7/site-packages/seatable_api/main.py", line 41, in parse_response raise ConnectionError(response.status_code, response.text) ConnectionError: [Errno 400] {"error_type":"param_row_ids_invalid","error_message":"param row_ids invalid"}
The error can’t be in my configuration - after all, the import of the headers and the first 10 entries works. What else could it be?
Grateful for any hint!
Greetings, Andreas
