API Limit & Plan
Hello, i using make.com
Plan Seatable Now : Free
Functions on make com, i use :
  1. List rows
  2. Add new row
  3. Delete row…
Questions :
On make.com, have error… maybe limit API…
1000 api per day?
Error Message :
The operation failed with an error. [429] Too Many Requests. Too many requests has been sent in a given amount of time
If i upgrade Enterprise, still limit 1000 api per day?
The API limits are independent of the plans. In other words, SeaTable Cloud Free, Plus and Enterprise are subject to the same constraints when it comes to API calling limits.
We deem that the API limits are sufficient for most use cases. If you run into the limits, then you should review your code first and seek to reduce API calls.
If you have exhausted your options to improve the script, SeaTable Dedicated, the premium hosted solution, offers higher limits. You can also self-host and up the limits in your system.
