API - SQL query with “Link to other records” fields
Hello!
I am trying to use the POST operations called List Rows (with SQL)
I have a table with “Link to other records” fields as you can see in the screenshot.
I am trying to retrieve the all dates from theis table where the proposal is {{proposal name}}.
I tried the following sql query:
“SELECT Date FROM Assigned Days WHERE Proposal = LAGALAYE yann 202408061”
It does not work because I can see that proposal is actually an array.
2024-02-06_14-46
Any help on how to achieve the expected result ?
Please check the document on “Extended List Operators”: SQL Reference - SeaTable Developer Manual
Thank you @daniel.pan I should have read more in depth!
