Base not found in sql
Hello, I think I have a bug
because by using the sql function of the api i can easily access my data and without changing anything in the sql code when i execute the code it tells me that it can’t find the database even though it exists and the id hasn’t changed. do you know why and how i can fix it :sweat_smile: ?
Did you hit the API limits? See here: https://manual.seatable.io/limitations/system_limitations/
no i didnt hit the API limits i only do 2 requests :sweat_smile:
but here is my error message if you want : {‘success’: False, ‘error_message’: ‘base a30fc064-b377-44df-9931-adb2b0f95d28 not found’, ‘results’: , ‘metadata’: }
I’m probably repeating myself but when I make a query that only looks at or modifies an existing line it works
and here is my sql in case : INSERT INTO server VALUES (“test”, “test”, “test”, “test”)
can someone help me :sweat_smile:
please can someone help me i need to use this :frowning:
Your SQL-Insert command uses the wrong syntax: You have to name all the target columns, and therefore it should be:
INSERT INTO table_name [column_list] VALUES value_list [, ...]
Here is the documentation about this:
https://seatable.github.io/seatable-scripts/python/sql/
Please try this new insert statement and if this is not working, please give more details:
  • which programming language do you use?
  • what does your complete script look like?
  • how is the structure of your base?
Best regards
Christoph
Hi
English is not my first language and I am not very good at it :sweat_smile:
and translators are unfortunately not very good at translating documentation.
Since I would like to learn, could you give me an example and if possible explain me a little :sweat_smile:
Thank you :pray:
You tried:
but it has to be:
INSERT INTO server (name_of_column1, name_of_column2, ...) VALUES (“test”, “test”, “test”, “test”)
Thanks a lot,
but trying to use this I still got the same error message:
{ 'success': False, 'error_message': 'base a30fc064-b377-44df-9931-adb2b0f95d28 not found', 'results': [], 'metadata': []}
and as you asked me here is my code :
import requests
import json
url = "https://cloud.seatable.io/dtable-db/api/v1/query/a30fc064-b377-44df-9931-adb2b0f95d28/"
payload = json.dumps({
  "sql": 'INSERT INTO server (ServerId, Prefix, Language, CommandActive, CommandDesactive) VALUES ("test", "test", "test", "test")',
  "convert_keys: True
headers = {
  'Authorization': 'Token hereismytoken',
  'Content-Type': 'application/json'
response = requests.request("POST", url, headers=headers, data=payload)
response = response.json()
print(response)
I have this same error. When I use the exact same base and token with a SELECT query it works fine. However, when I try the INSERT query, I get this error
( I have removed the base uuid):
"success":
false,
"error_message":
"base base_uuid not found",
"results":
"metadata":
