I’m trying to use the API, but I’m failing with the base token. According to the docs, the token should be 249 characters long. Using the API token and the “app-access-token” endpoint, the “access_token” attribute contains 492 characters. When using this one as base token for other endpoints, an “Invalid token” error is returned.
Can anyone confirm the length of the token?
