Bug in dateAdd() formula
Hello everyone,
As you can see in the attached photos, I have three columns:
  • Start Time
  • Planned Duration (POM)
  • End Time
In the End Time column, I would like to add the Planned Duration (POM) to the Start Time in hour format. However, as shown in the End Time column, the hour and minute are not displayed.
I would be grateful if anyone could assist me with this issue.
Thank you.
Hi @Hossein, and welcome to the SeaTable forum!
Probably you should just edit the output format of your End Time column. For that:
  • click the black downwards triangle on the right of the end time column header
  • click Edit format settings
  • select one of the four latest format which include both date and time
Bests,
Benjamin
Thank you. It works. I have not seen that before.
