Call Function From Different Script File
Hey!
Just started out with seatable.io yesterday and it is fun to use!
My question: Is there a way to call a function in a script that is defined in a different script file?
So I can create a file with some helper functions and re-use these helper function in a different script?
Right now the code in the scripts becoming very repetitive.
This relates to Python and JS as well.
Best René
Glad you like SeaTable.
In SeaTable Cloud, there is no easy way to achieve what you wish to do.
The story is different when you self-host. Then you can install custom Python modules in your Python Runner. More here: Custom Python Runner - SeaTable Admin Manual
I understand. Thank you.
