Cascaded select option is limited?
Tried to setup two columns with a cascaded single select field.
Filled first column with 12 entries and the second one with 97 options. So far, so fine.
Then I wanted to define the cascade, setup the dependencies and ran into problems.
At some point the first column was shortened to 8 entries and is not accepting any more entries anymore.
Is there a limit of 8 select options when cascaded?
If so, is it a general limit or does it exist in the free version only?
solved
After de-selecting some dependencies in the second column, I was able to add new entries to the first one. Now there seems to be no limit. No clue why this happened
Pleased to hear that you could solve your problem.
