Column with row_id
Hello!
How can I get the row_id in a column?
In Airtable I can do it using a formula and typing RECORD_ID()
Can I use something similar in SeaTable?
Thank you!
Hi @nico1.
As far as I know the row ID is only used internally and for api / javascript and python. If you need a unique ID you should go for the “Auto number” or if you need it more specialized combine the auto number with the formula column.
Regards
Thank you for answer!
Regards.
