Combined filters
Hi,
I’m using the cloud version (and Android App).
I would like to find a way to combine AND and OR filters. For now it is only possible to select one type of filter. So I can only set up AND filters or OR filters but not both.
For Instance, I would like to set up a filter like this one : Filed1 AND Field2 AND (Field3 OR Field4).
Does anyone know how I can do this?
Many thanks for your help
Complex filters aren’t supported yet. This will be added in the foreseeable future.
For now, you may solve your problem by adding an auxiliary formula column.
Thank yoy @rdb
Yes I actually use a formula column.
Thank you
