Common Issues Encountered During Data Import into SeaTable
I am importing data into SeaTable using an Excel file in XLSM format; however, during the import process, the system automatically omits and fails to update an entire column.
This occurs despite having synchronized both the column names and data formatting accordingly. I conducted a test by creating a new base, and the system mapped this column successfully.
Could you please assist in investigating the underlying cause of this phenomenon?
Are you using SeaTable Cloud or a self-hosted installation?
What is the column type/data formatting of the column that is not correctly imported?
Does your import problem persist?
