Counting "selections" from multiple fields in each row
Does anyone know if and how it is possible to count how many times a given “choice” has been chosen in multiple single select fields?
In my example, I am trying to create a security score based on a 1-4 scale ( on different Security areas, Eg. backup, restore, access control, and more. Let’s say I have 20 different areas of which each has a score between 1-4. Now I want to sum up the score, but I would like to do so without creating 20 new columns with if statements that convert the single select to numbers, which I could then aggregate. That would be time-consuming and hard to maintain as I add new ones,
Basically, I want to do something like "count if any single select field in row = “Inadequate” " and then three similar ones for the other relevant choices in the single select.
You can use the switch() function.
This is my table:
This is the formula i used:
Simple enough, right? And pretty flexible too!
Fantastic! It is the perfect solution!
Wonderful. I was hoping you’d say that.
