CSV Import: File xxxxxxx.csv is too large
I am trying to import a 16mb CSV file with 10000 rows into an on-prem Seatable instance (8gb stock DigitalOcean install) and I get a notification that says File g_feed_v2_SKU_WE_Short.csv is too large.
If I truncate the CSV to 7000 rows, it works.
I’d like to be able to import up to 100k rows. Is there a soft-limit somewhere that I can tweak?
Please have a look at this release note, specifically the part about bulk import from Excel: SeaTable 3.3: Improved form editor and HTML e-mail support
Very cool! I wasn’t able to use the “import from xlsx to big data storage” button because I got a “Column not match” error, but the traditional way seems to work much better with xlsx than CSV.
Screen Shot 2023-01-24 at 5.50.23 PM
This is a precise error message which you can work with, right?
Can you elaborate?
Nevermind! Turns out we had a blank header field. Sorry to have wasted your time.
