Hi there,
it has been a while since I used Seatable.
The primary reason to stop using Seatable was the lack of customizations options in the Row Details view (pressing space on a row). I would like to alter the order of fields, add some free text, hide fields, etc. (more like creating a form) Just to make the edit a row view a little bit more user friendly.
Any plans for adding these features?
Thanks!
I can’t promise an exact date, but in the next few months we will release a new feature that allows you to create your own interfaces. We call this feature “universal app”. I am sure you will be excited about this feature.
It has been a long time since I last used seatable. With renewed curiosity, I look at the latest developments. And in doing so, I also come back to this question asked in 2022. Is this request still on the roadmap?
Custom layouts for the row details are not on the roadmap. Sorry.
But the above-mentioned app builder may be a good alternative. You should take a look! The app builder is extremely powerful! Imagine the base as the (database) backend and the app(s) as the frontend to your no-code tool. You build internal and client-oriented apps in no time and with no code.
