Duplicate Base or duplicate column header and formula
Hello, are we able to duplicate base ? I have one specific base , it is not working well with n8n trigger. I am not sure of the reason. But when i try with other base, it is working.
I would like to duplicate the affected base or import the column title to the newly created base.
is there anyway i could do it?
You can export the base as a DTABLE-file and then reimport.
Hello @rdb thank you for your help. I can export the Dtable file, but may i know how do i import it ?
Hi there! Reimporting is simple: Create a new base and choose “Import from file”
grafik
@rdb thank you very much… :star_struck: forget to check it when creating a new base…
Glad I could help. :smiley:
