ERROR 1054 (42S22) at line 68: Unknown column 'token' in 'dtable_external_apps'
Hello
After running the schema update we got this error:
root@74fa9a0e37bc:/opt/seatable# mysql -h$DB_HOST -p$DB_ROOT_PASSWD dtable_db </opt/seatable/seatable-server-latest/sql/mysql/upgrade/4.3/dtable.sql
mysql: [Warning] Using a password on the command line interface can be insecure.
Upgrade from 4.2.11 to 4.3.8.
But seatable works OK, we don’t see any issues.
You probably forgot running an update script in the past.
The error message is precise: the column ‘token’ is missing in table ‘dtable_external_apps’.
Check the update scripts of prior versions for the relevant
ALTER TABLE dtable_external_apps ADD token
Query. Run the SQL statement manually.
The solution is simpler. With version 4.3 you don’t have to run database update scripts anymore:
https://admin.seatable.io/upgrade/upgrade_manual/
This error occurs, because you execute it again and it tries to rename a column that does not exist anymore.
# this is the request that can not be executed twice...
ALTER TABLE `dtable_external_apps` RENAME COLUMN `token` to `app_uuid`;
