Hi, anyone else having problems importing the API into Postman? I’m getting these errors in both the Postman Windows app and in Postman for Web after clicking the “Run in Postman” button on the API pages. Running latest version of Postman (v9.12.0).
I confirmed this happened to me 3 times in a row. However oddly enough I restarted postman twice thinking maybe was an error on postman side and ended up with the library being imported 3 times. Try that out? Then just delete the extra out if it works
Is this still an issue?
I tried again this morning and initially it was still an issue via the Windows app. I tried the web app again and this time it worked. Interestingly it then imported the API about 15 times, all dated on the 3rd Feb when I was originally trying. So there is still something funky going on with the import process.
Thanks for reporting back.
Since the problem has been solved, I take the liberty of marking this as such.
