Failing to download images via REST-API for shared base
Your Setup:
  • SeaTable Cloud
With respect to a question I asked long time ago:
https://forum.seatable.io/t/how-to-get-an-api-token-for-a-shared-base/2562/2
I am reading in a base shared with me. I can successfully dowwload table data (using JavaScript). Now, this table has associated images. I fail to download those with the AccessToken. But I cannot create an API-Token either.
What possibility do I have here? Do I really need an API-Token? I can see those images in the UI, so, they are accessible somehow with my authentication.
Many thanks for any hints,
-Markus
You can download images using a Python script. You find more info here.
Using Python I will have the same problem - which is getting an API-Token for a shared base.
