Field not showing when using condition with field number in
Hey,
I have an app webform with different fields, some of them with “show field conditions”.
Everything went good until I tried to add a condition depending on a number field. In this case, my field does’nt appear.
Some exemples :
Case 1: using a multiple selection fiels, condition is working
Case 2: using a number field, condition is not working
I tried with different conditions (“=0”, “>5”, “is empty”, etc.), and I have the same behaviour.
Any idea where the problem could be ?
Thanks for your help
Please try with a value <> 0. Try value 1. Does the problem persist?
Yes problem persists with “Field1 = 1”
With the value <>0, my field is displayed when I open the page, whatever Field1 is empty, 0 or something else by default.
And it doesn’t disappear if I change its value.
Could you send an invite link for this base to support@seatable.io? We’d like to take a look.
Yes sure, I’m sending an invite link right now.
Let me know if I can do anything to help
The root cause is the column format of the evaluated field. When the format is set to €/$/… the evaluation always returns False.
The quick fix: Set the column format to just “Number”.
We’ll fix this. In fact, it is going to be fixed in SeaTable 5.2 scheduled for release mid-month.
