Formatted mail text in 4.3: Bug / Missing Feature concerning Links
Hi! Sending formatted mails from automations is great! Thanks for adding this feature!
A litte glitch: Using Links from fields with {column name} doesn’t seem to work:
● When we create such dynamic links, the dialog where you enter the URL jumps to an empty page
● Our workaround was to create a fixed link, then copy this one, and modify it, entering {column name} as the (dynamic) link URL
Doesn’t work: The placeholder {column name} is never substituted with the actual Link URL from the column.
All we can do now is insert {column name} directly into the text, which makes the link non-clickable text in the resulting mail. Creating a proper link would be nice.
Again: Functionality is great, and this is just a minor glitch.
We will check issue.
Do you record your the URL in a link column?
If we support “{a-link-column}” to be replaced by a clickable link (instead of plain text) in the email template, do you think if it can meet your need?
@daniel.pan Hey Daniel, we’ve got a similar problem.
We are using placeholder in our emails like {email} {first_name} etc. but the placeholder is not getting replaced in the sent email.
The client email looks like that:
2024-02-26 um 15-40-14
Do you send rich text emails via button or an automation?
If you send via button, you cannot use {column name}. You must use menu bar icon to insert column references:
This is an inconsistency between the rich text editor that will be changed in a future version.
@rdb Thank you so much - this solution works for us. Yes, we’ve been using a button :slight_smile:
We will check the issue.
Hi, I now re-checked this issue in 5.0, and it has improved (a bit ;-).
Use case: I want to dynamically change part of a link in an email with the content of a column that triggers the mail (automation / button). Or, more precisely, I’d like to pre-fill a seatable form that is opened when the user clicks of the link in the E-Mail.
The use case in complete steps:
  • I create a new user with name “FIRST LAST” in Seatable
  • With an automation, a mail is sent with the content:
Hello User {name}
we just registered you. Please fill out this form to tell us more about you:
https://seatable.mydomain.com/dtable/forms/custom/prefilled/?prefillForce_name={name}
  • Clicking on the link opens a form with the “name” field prefilled with the user’s name. This is for convenience, and to make sure the User’s name provides a consistent link from the user input to the registration record in the other table.
This is what I found out in Seatable 5.0.7
  • Partly works with mail text in plain text
    • Depends on the recipient’s mail client whether the URL is clickable
    • {name} needs to be urlencoded by hand - since there is no formula functions, I do the main replacement like “substitute({name},” “,”%20")" somewhat clumsily
  • Barely works with Rich Text mail
    • Only if the link is not treated as a link, but as text
    • That implies that a link text cannot be set - the URL is visible as in plain text
    • The rest like encoding and the dependency upon the mail client to be able to click on the link is the same.
In a perfect world, Seatable would have a nice function to include column values into a URL, urlencode them, and show a nice, clickable link with a nice link text.
Thanks for the detailed reply. We will check the problem again.
