Formula in first column not showing in linkage view
Hi all,
there seems to be a problem with the visibility of the first column in linkage views when the first column contains a formula. Look at the example:
I have a table with persons. The first column has a concatanation formula to combine first and last name:
Then there is a group table with column “person” linked to “person” table rows:
However, in the “Link hinzufügen” view I do not see “Peter Miller”. The respective part of the entry is just empty.
In contrast to this, when I add a “friend” column in the “person” table that references to other rows in the same table, the formula value is displayed correctly:
I guess this is a bug, isn’t it?
Best,
Simon
Seatable EE 3.5.10
Thank you for your feedback. I have tested and reproduced this issue, and we will fix it in the next version. :smiley:
Great - thanks! :slight_smile:
Best,
Simon
