Free Plan - Row
With the free plan, is it possible to copy 2 rows in rows of another table? If yes, how? If no, is it possible to do this with another plan? If yes Which one?
I don’t understand the question.
Please provide a more precise description - in topic title and description.
yes, of course. I would like to know if it is possible to copy 1 box of one table to 1 box of another table With the free plan?
The user manual is not perfect, but it contains a lot of helpful information: Die Schaltfläche - SeaTable
Thank you.
Moreover, if I try to send an email with the button in the Text field and in the email field while using it does not recognise the data, e.g.
Message
Hi [name]
and email
[email] and does not send the email.
Could you help me, please?
Column references must be in braces { }, not brackets .
But this is explained explicitly in the button’s configuration dialog and in the user manual.
