Generate PDF directly from webform
Hey,
is there any way to create a PDF file directly from a webform and safe it in SeaTable?
Or do I have to create a PDF with the data from the webform in the base using the page design plugin?
Hi,
you cannot create a PDF file from a form.
As you correctly say, the data from your form has to be transferred to your Base first and then the PDF file can be created using the Page Design plugin and the button.
