Google Calendar connection doesn't work
Your Setup:
  • SeaTable Cloud
I am very new at database topics and still learning. I can’t connect Google Calendar to SeaTable in the third-party integration. After filling in the various information, it displays the following message
Is it something that I didn’t complete well, or a seatable problem with google ?
Thx,
There a step-by-step how-to for configuring a Google Calendar Account in SeaTable.
Did you follow that? If you did not follow the instructions, why should SeaTable be the problem?
