Hitting "tab" when in a sorted view puts the cursor into the wrong row
Your Setup:
  • Cloud
When in a sorted view when I hit ‘tab’ to go to the next cell in the row the cursor jumps to the wrong row. In a typical database or spreadsheet, even sorted or categorized, hitting “tab” will cause the cursor to jump to the next cell in that row. But in SeaTable there is a glitch; if the view is ‘sorted’ the row will auto-sort after entering text in a cell (which is good) but then when hitting ‘tab’ the cursor does not say in that row; when it auto sorts it leaves the cursor behind and it ends up in a different row. This is a dangerous flaw for data integrity. I’m requesting an immediate fix to the glitch so that “tab” will move the cursor to the next cell whether in a sorted view or not. Thanks!
