Horizontal scroll doesn't work
Hey everyone,
We’re facing a bug with Seatable: horizontal scrolling isn’t working, across different browsers and user in one table, but it works in the other ones. Any ideas on how to fix this?
Thanks!
Please share with us:
  • Do you use SeaTable Cloud or your own SeaTable Server
  • Where is horizontal scrolling impaired? In only one table?
  • Can you send a screenshot of your browser console?
  • we are using the SeaTable Cloud
  • yes only in one, the others are fine
@Leo.Shi Could you take a look?
Any ideas how to solve it? We can’t really work like this…
Hello, if you have set up many frozen columns? If many frozen columns are set on a large-sized screen, and all columns are frozen on a small-sized screen, it looks like horizontal scrolling is ineffective.
And is it convenient to take a screenshot, including the image of the table interface?
Actually it was really as easy and the frozen boarder somehow was too right all of a sudden. Thanks!
My personal response of the month !
